Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your hoverboard will not turn on, follow this guide to replace the power button.
Partes
No se especificaron partes.
  1. Flip the hoverboard so the bottom is facing up. The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it. Grip the bottom right panel and lift to remove it.
    • Grip the bottom right panel and lift to remove it.
  4. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  5. Disconnect the battery by holding the yellow connectors and pulling apart. Disconnect the battery by holding the yellow connectors and pulling apart.
    • Disconnect the battery by holding the yellow connectors and pulling apart.
  6. Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board. You can also unplug the light connector to free up your work space. You can also unplug the light connector to free up your work space.
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
  7. Use an adjustable wrench to remove the 14 mm nut holding the button in the shell. Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
  8. Pull the power button out of the panel. Replace the power button. Replace the power button.
    • Pull the power button out of the panel.
    • Replace the power button.
Conclusión
Alexander Pham
Miembro Desde 07/10/18
209 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S15-G4, White Fall 2018 Miembro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 91
