Introducción
If your hoverboard will not turn on, follow this guide to replace the power button.
Qué necesitas
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Disconnect the battery by holding the yellow connectors and pulling apart.
