Saltar al contenido principal
Hover-1 Titan Left Gyroscope Replacement
Qué necesitas
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: paso 1, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: paso 1, imagen 2 de 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Left Gyroscope Replacement: paso 2, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Left Gyroscope Replacement: paso 3, imagen 1 de 3 Hover-1 Titan Left Gyroscope Replacement: paso 3, imagen 2 de 3 Hover-1 Titan Left Gyroscope Replacement: paso 3, imagen 3 de 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: paso 4, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: paso 4, imagen 2 de 2
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Left Gyroscope Replacement: paso 5, imagen 1 de 3 Hover-1 Titan Left Gyroscope Replacement: paso 5, imagen 2 de 3 Hover-1 Titan Left Gyroscope Replacement: paso 5, imagen 3 de 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Left Gyroscope Replacement: paso 6, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 6, imagen 2 de 2
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Left Gyroscope Replacement: paso 7, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 7, imagen 2 de 2
    • Unplug the light connector by squeezing it and pulling away from the board.
  8. Hover-1 Titan Left Gyroscope Replacement: paso 8, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 8, imagen 2 de 2
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Left Gyroscope Replacement: paso 9, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 9, imagen 2 de 2
    • Unplug the small white connector by squeezing it and pulling away from the board.
  10. Hover-1 Titan Left Gyroscope Replacement: paso 10, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 10, imagen 2 de 2
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
  11. Hover-1 Titan Left Gyroscope Replacement: paso 11, imagen 1 de 2 Hover-1 Titan Left Gyroscope Replacement: paso 11, imagen 2 de 2
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
  12. Hover-1 Titan Left Gyroscope Replacement: paso 12, imagen 1 de 1
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
Conclusión
Jessica Ouyang
Miembro Desde 10/08/18
619 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S15-G4, White Fall 2018 Miembro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Miembros
10 Guías creadas
2 comentarios
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Contestar
Where do you buy the board?
eden11 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 995
