Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Partes
No se especificaron partes.
  1. Flip the hoverboard so the bottom is facing up. The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove. Grip the bottom left panel and lift up to remove.
    • Grip the bottom left panel and lift up to remove.
Conclusión
Dana Ebe
Miembro Desde 08/10/18
196 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S15-G4, White Fall 2018 Miembro de Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 30
