Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Hover-1 Superstar Speaker Replacement
Qué necesitas
  1. Hover-1 Superstar Speaker Replacement, Bottom Case: paso 1, imagen 1 de 3 Hover-1 Superstar Speaker Replacement, Bottom Case: paso 1, imagen 2 de 3 Hover-1 Superstar Speaker Replacement, Bottom Case: paso 1, imagen 3 de 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
    Pregunta a FixBot
    Agregar Comentario
  2. Hover-1 Superstar Speaker Replacement: paso 2, imagen 1 de 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    Pregunta a FixBot
    Agregar Comentario
  3. Hover-1 Superstar Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Unplug the white connector that connects the speaker itself with the circuit board attached to the bottom of the device case.
    Pregunta a FixBot
    Agregar Comentario
  4. Hover-1 Superstar Speaker Replacement: paso 4, imagen 1 de 1
    • Unscrew all three 9mm screws with a Phillips #0 screwdriver securing the speaker to the device case.
    Pregunta a FixBot
    Agregar Comentario
  5. Hover-1 Superstar Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the speaker from its port.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 32
Todo El Tiempo: 564
