Introducción
Often times the lights on the Hover-1 Superstar stop working and need to be replaced. This guide will explain the short series of steps involved in fixing issues with the lights on the device.
Partes
No se requieren partes.
  1. Flip  your Hover-1 Superstar device upside down.
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Locate the cable connected to the front lights.
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 38
Todo El Tiempo: 54
