Introducción
Often times the lights on the Hover-1 Superstar stop working and need to be replaced. This guide will explain the short series of steps involved in fixing issues with the lights on the device.
Qué necesitas
Flip your Hover-1 Superstar device upside down.
Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
Remove the bottom case. Be careful of the connector holding the case and the device together.
Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
