Saltar al contenido principal
Hover-1 Superstar Front Bumper LED Replacement
Qué necesitas
  1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: paso 1, imagen 1 de 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: paso 1, imagen 2 de 3 Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: paso 1, imagen 3 de 3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Front Bumper LED Replacement: paso 2, imagen 1 de 1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: paso 3, imagen 1 de 1
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 366
