Saltar al contenido principal
Hover-1 Rally Rear Wheel Replacement
Qué necesitas
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: paso 1, imagen 1 de 1
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
  2. Hover-1 Rally Rear Wheel Replacement: paso 2, imagen 1 de 1
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
  3. Hover-1 Rally Rear Wheel Replacement: paso 3, imagen 1 de 2 Hover-1 Rally Rear Wheel Replacement: paso 3, imagen 2 de 2
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
  4. Hover-1 Rally Rear Wheel Replacement: paso 4, imagen 1 de 1
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Conclusión
Una persona más ha completado esta guía.
Cami Lowrey
Miembro Desde 02/07/20
441 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S7-G2, Regan Winter 2020 Miembro de Cal Poly, Team S7-G2, Regan Winter 2020
CPSU-REGAN-W20S7G2
6 Miembros
7 Guías creadas
Un comentario
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,030
