Introducción
If your Nomad does not power on, the power button may be damaged. Follow this guide to replace the power button in the Hover-1 Nomad.
Qué necesitas
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Peel off the glue around the power button.
Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
Una persona más ha completado esta guía.
