Saltar al contenido principal
Hover-1 Maverick Motor Wheel Replacement
Qué necesitas
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: paso 1, imagen 1 de 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: paso 1, imagen 2 de 3 Hover-1 Maverick Motor Wheel Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motor Wheel Replacement: paso 2, imagen 1 de 2 Hover-1 Maverick Motor Wheel Replacement: paso 2, imagen 2 de 2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motor Wheel Replacement: paso 3, imagen 1 de 2 Hover-1 Maverick Motor Wheel Replacement: paso 3, imagen 2 de 2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motor Wheel Replacement: paso 4, imagen 1 de 2 Hover-1 Maverick Motor Wheel Replacement: paso 4, imagen 2 de 2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: paso 5, imagen 1 de 2 Hover-1 Maverick Motor Wheel Replacement, Motor: paso 5, imagen 2 de 2
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. Hover-1 Maverick Motor Wheel Replacement: paso 6, imagen 1 de 1
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
Conclusión
Piper Feldman
Miembro Desde 01/23/20
409 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S2-G2, White Winter 2020 Miembro de Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 484
