Saltar al contenido principal
Hover-1 Maverick Battery Replacement
Qué necesitas
  1. Hover-1 Maverick Battery Replacement, Battery: paso 1, imagen 1 de 2 Hover-1 Maverick Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell.
  2. Hover-1 Maverick Battery Replacement: paso 2, imagen 1 de 3 Hover-1 Maverick Battery Replacement: paso 2, imagen 2 de 3 Hover-1 Maverick Battery Replacement: paso 2, imagen 3 de 3
    • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
    • Lift off the black plastic retaining bracket.
  3. Hover-1 Maverick Battery Replacement: paso 3, imagen 1 de 2 Hover-1 Maverick Battery Replacement: paso 3, imagen 2 de 2
    • Pull the battery upward lightly to remove from the device.
    • The battery is secured to the device with adhesive tape.
Conclusión
Una persona más ha completado esta guía.
Piper Feldman
Miembro Desde 01/23/20
409 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S2-G2, White Winter 2020 Miembro de Cal Poly, Team S2-G2, White Winter 2020
CPSU-WHITE-W20S2G2
2 Miembros
4 Guías creadas
2 comentarios
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - Contestar
Where can I find that same battery i cant find one
Toad Blue - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 46
Todo El Tiempo: 2,961
