Saltar al contenido principal
Hover-1 Matrix Pad Replacement
Qué necesitas
  1. Hover-1 Matrix Pad Replacement, Pad: paso 1, imagen 1 de 2 Hover-1 Matrix Pad Replacement, Pad: paso 1, imagen 2 de 2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: paso 2, imagen 1 de 1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: paso 3, imagen 1 de 1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: paso 4, imagen 1 de 2 Hover-1 Matrix Pad Replacement: paso 4, imagen 2 de 2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: paso 5, imagen 1 de 3 Hover-1 Matrix Pad Replacement: paso 5, imagen 2 de 3 Hover-1 Matrix Pad Replacement: paso 5, imagen 3 de 3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: paso 6, imagen 1 de 1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
Conclusión
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
Una persona más ha completado esta guía.
Jici Zhuang
Miembro Desde 10/22/18
362 Reputación
2 Guías creadas
Equipo
UC Davis, Team S7-G2, Lore Fall 2018 Miembro de UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 337
