Introducción
Gyroscopes help to control orientation. If it is hard to control hoverboard's orientation during driving, people can change the gyroscopes.
  1. Use screw driver to remove screws on the back of the hover board and then remove the back shell as the second image shows. In the third image, there is screw driver we used from the 54 bit driver kit.
    • Use screw driver to remove screws on the back of the hover board and then remove the back shell as the second image shows. In the third image, there is screw driver we used from the 54 bit driver kit.
  2. The gyroscopes is the green electric board at the end of both sides of the hover board. Use the screw driver to remove screws at the corner of the gyroscopes as the first image shows. Then, you can remove the whole board as the second image shows.
    • The gyroscopes is the green electric board at the end of both sides of the hover board. Use the screw driver to remove screws at the corner of the gyroscopes as the first image shows. Then, you can remove the whole board as the second image shows.
Conclusión
Qingxi Liu
Miembro Desde 22/10/18
85 Reputación
1 Guía escrita
Equipo
UC Davis, Team S7-G2, Lore Fall 2018 Miembro de UC Davis, Team S7-G2, Lore Fall 2018
UCD-LORE-F18S7G2
3 Miembros
4 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 23
