Saltar al contenido principal
Hover-1 Liberty Bottom Cover Replacement
Qué necesitas
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: paso 2, imagen 1 de 2 Hover-1 Liberty Bottom Cover Replacement: paso 2, imagen 2 de 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: paso 3, imagen 1 de 3 Hover-1 Liberty Bottom Cover Replacement: paso 3, imagen 2 de 3 Hover-1 Liberty Bottom Cover Replacement: paso 3, imagen 3 de 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Conclusión
2 personas más completaron esta guía.
Patrick Bacon
Miembro Desde 10/08/18
405 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G2, White Fall 2018 Miembro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Miembros
4 Guías creadas
2 comentarios
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Contestar
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 17
Ultimos 30 días: 52
Todo El Tiempo: 2,780
