Saltar al contenido principal
Hover-1 Liberty Battery Replacement
Qué necesitas
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: paso 1, imagen 1 de 2 Hover-1 Liberty Battery Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Battery Replacement: paso 2, imagen 1 de 2 Hover-1 Liberty Battery Replacement: paso 2, imagen 2 de 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Battery Replacement: paso 3, imagen 1 de 3 Hover-1 Liberty Battery Replacement: paso 3, imagen 2 de 3 Hover-1 Liberty Battery Replacement: paso 3, imagen 3 de 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Battery Replacement, Battery: paso 4, imagen 1 de 2 Hover-1 Liberty Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
  5. Hover-1 Liberty Battery Replacement: paso 5, imagen 1 de 2 Hover-1 Liberty Battery Replacement: paso 5, imagen 2 de 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
  6. Hover-1 Liberty Battery Replacement: paso 6, imagen 1 de 2 Hover-1 Liberty Battery Replacement: paso 6, imagen 2 de 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
  7. Hover-1 Liberty Battery Replacement: paso 7, imagen 1 de 3 Hover-1 Liberty Battery Replacement: paso 7, imagen 2 de 3 Hover-1 Liberty Battery Replacement: paso 7, imagen 3 de 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
Conclusión
Una persona más ha completado esta guía.
Patrick Bacon
Miembro Desde 10/08/18
405 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G2, White Fall 2018 Miembro de Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 40
Todo El Tiempo: 2,096
