Saltar al contenido principal
Hover-1 Horizon Wheel Wires Replacement
Qué necesitas
  1. Hover-1 Horizon Wheel Wires Replacement, Base Plate: paso 1, imagen 1 de 2 Hover-1 Horizon Wheel Wires Replacement, Base Plate: paso 1, imagen 2 de 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Wheel Wires Replacement: paso 2, imagen 1 de 2 Hover-1 Horizon Wheel Wires Replacement: paso 2, imagen 2 de 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Wheel Wires Replacement: paso 3, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 3, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 3, imagen 3 de 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: paso 4, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: paso 4, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: paso 4, imagen 3 de 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Wheel Wires Replacement: paso 5, imagen 1 de 2 Hover-1 Horizon Wheel Wires Replacement: paso 5, imagen 2 de 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Wheel Wires Replacement: paso 6, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 6, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 6, imagen 3 de 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Wheel Wires Replacement: paso 7, imagen 1 de 2 Hover-1 Horizon Wheel Wires Replacement: paso 7, imagen 2 de 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Wheel Wires Replacement: paso 8, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 8, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 8, imagen 3 de 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Wheel Wires Replacement: paso 9, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 9, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 9, imagen 3 de 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Wheel Wires Replacement, Wheel Wires: paso 10, imagen 1 de 2 Hover-1 Horizon Wheel Wires Replacement, Wheel Wires: paso 10, imagen 2 de 2
    • Remove the four 30mm Hex #6 screws.
  11. Hover-1 Horizon Wheel Wires Replacement: paso 11, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 11, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 11, imagen 3 de 3
    • Remove the metal square by lifting it up and setting it to the side.
  12. Hover-1 Horizon Wheel Wires Replacement: paso 12, imagen 1 de 1
    • Check that all the clips are secured properly.
  13. Hover-1 Horizon Wheel Wires Replacement: paso 13, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 13, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 13, imagen 3 de 3
    • Remove the clip by squeezing the latch that holds the clips together while pulling apart.
    • Check motion of the wheel after the clip is disconnected. If the wheel is still stuck, reconnect the clip and disconnect the next one.
    • Remove the clip by squeezing the tab while pulling the clip apart.
  14. Hover-1 Horizon Wheel Wires Replacement: paso 14, imagen 1 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 14, imagen 2 de 3 Hover-1 Horizon Wheel Wires Replacement: paso 14, imagen 3 de 3
    • Disconnect the remaining three clips by pulling them apart.
    • After each clip is disconnected, check to see if the motion of the wheel has improved. If the wheel is still stuck, reconnect the clip and unclip the next one.
Conclusión
Jenny Dyer
Miembro Desde 10/08/18
235 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G6, White Fall 2018 Miembro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 32
Todo El Tiempo: 373
