Saltar al contenido principal
Hover-1 Horizon Power Button Replacement
Qué necesitas
  1. Hover-1 Horizon Power Button Replacement, Base Plate: paso 1, imagen 1 de 2 Hover-1 Horizon Power Button Replacement, Base Plate: paso 1, imagen 2 de 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Power Button Replacement: paso 2, imagen 1 de 2 Hover-1 Horizon Power Button Replacement: paso 2, imagen 2 de 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Power Button Replacement: paso 3, imagen 1 de 3 Hover-1 Horizon Power Button Replacement: paso 3, imagen 2 de 3 Hover-1 Horizon Power Button Replacement: paso 3, imagen 3 de 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Power Button Replacement, Power Button: paso 4, imagen 1 de 1
    • Reorient the Hover-1 Horizon so the base plate opens towards you.
  5. Hover-1 Horizon Power Button Replacement: paso 5, imagen 1 de 3 Hover-1 Horizon Power Button Replacement: paso 5, imagen 2 de 3 Hover-1 Horizon Power Button Replacement: paso 5, imagen 3 de 3
    • Remove the connector by squeezing the tab and lifting up.
  6. Hover-1 Horizon Power Button Replacement: paso 6, imagen 1 de 3 Hover-1 Horizon Power Button Replacement: paso 6, imagen 2 de 3 Hover-1 Horizon Power Button Replacement: paso 6, imagen 3 de 3
    • Remove the second connector by squeezing the tab and pulling up.
  7. Hover-1 Horizon Power Button Replacement: paso 7, imagen 1 de 3 Hover-1 Horizon Power Button Replacement: paso 7, imagen 2 de 3 Hover-1 Horizon Power Button Replacement: paso 7, imagen 3 de 3
    • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
    • Push the power button through the base plate to remove.
    • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
Conclusión
Christina Fong
Miembro Desde 10/08/18
165 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S13-G6, White Fall 2018 Miembro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 297
