Saltar al contenido principal
Hover-1 Horizon Left Gyroscope Sensor Board Replacement
Qué necesitas
  1. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: paso 1, imagen 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: paso 1, imagen 2 de 2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 2, imagen 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 2, imagen 2 de 2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 3, imagen 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 3, imagen 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 3, imagen 3 de 3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: paso 4, imagen 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: paso 4, imagen 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: paso 4, imagen 3 de 3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 5, imagen 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 5, imagen 2 de 2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 6, imagen 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 6, imagen 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 6, imagen 3 de 3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 7, imagen 1 de 2 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 7, imagen 2 de 2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 8, imagen 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 8, imagen 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 8, imagen 3 de 3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 9, imagen 1 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 9, imagen 2 de 3 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: paso 9, imagen 3 de 3
    • Unclip the black connector by squeezing both sides and pulling them apart.
Conclusión
Una persona más ha completado esta guía.
Casey Winans
Miembro Desde 10/08/18
324 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G6, White Fall 2018 Miembro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 37
Ultimos 30 días: 191
Todo El Tiempo: 1,628
