Introducción
Is one side of your Hover-1 Horizon unresponsive? This is a guide to show you how to replace the gyroscope broad, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
  1. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
    • Remove the middle connector by squeezing the top of the tab and pulling up.
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    • Unclip the black connector by squeezing both sides and pulling them apart.
Conclusión
Una persona más ha completado esta guía.
Casey Winans
Miembro Desde 08/10/18
306 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S13-G6, White Fall 2018 Miembro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 24
Todo El Tiempo: 130
