Introducción
Is your hoverboard unbalanced or leaning to one side while riding? This is a guide to show you how to remove the balance sensor tab on the Hover-1 Horizon, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
  1. Remove the six 12mm Phillips #2 screws holding the base plate.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
    Agregar Comentario
  2. Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
    Agregar Comentario
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
    Agregar Comentario
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
    Agregar Comentario
  3. GIVE TOOLS. FIX FOREVER.
    GIVE TOOLS.
    FIX FOREVER.
    Spread the Fixmas cheer.
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
    Agregar Comentario
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
    Agregar Comentario
    • Remove the middle connector by squeezing the top of the tab and pulling up.
    Agregar Comentario
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
    Agregar Comentario
    • Unclip the black connector by squeezing both sides and pulling them apart.
    Agregar Comentario
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
    Agregar Comentario
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
    Agregar Comentario
Conclusión
Jesus
Miembro Desde 08/10/18
85 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S13-G6, White Fall 2018 Miembro de Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 5
Todo El Tiempo: 61
