Saltar al contenido principal
Hover-1 H1 Shell Replacement
Qué necesitas
  1. Hover-1 H1 Shell Replacement, Bottom Shell: paso 1, imagen 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Shell Replacement: paso 2, imagen 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Shell Replacement: paso 3, imagen 1 de 2 Hover-1 H1 Shell Replacement: paso 3, imagen 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Shell Replacement: paso 4, imagen 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Shell Replacement, LED Headlights: paso 5, imagen 1 de 1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 Shell Replacement: paso 6, imagen 1 de 1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 Shell Replacement: paso 7, imagen 1 de 1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
  8. Hover-1 H1 Shell Replacement, Charging Port: paso 8, imagen 1 de 2 Hover-1 H1 Shell Replacement, Charging Port: paso 8, imagen 2 de 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  9. Hover-1 H1 Shell Replacement: paso 9, imagen 1 de 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  10. Hover-1 H1 Shell Replacement: paso 10, imagen 1 de 2 Hover-1 H1 Shell Replacement: paso 10, imagen 2 de 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  11. Hover-1 H1 Shell Replacement: paso 11, imagen 1 de 2 Hover-1 H1 Shell Replacement: paso 11, imagen 2 de 2
    • Pull the charging port to the left through the shell.
  12. Hover-1 H1 Shell Replacement, Power Button: paso 12, imagen 1 de 1
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
  13. Hover-1 H1 Shell Replacement: paso 13, imagen 1 de 2 Hover-1 H1 Shell Replacement: paso 13, imagen 2 de 2
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
  14. Hover-1 H1 Shell Replacement: paso 14, imagen 1 de 1
    • Pull the power button through the hole in the shell.
  15. Hover-1 H1 Shell Replacement, Shell: paso 15, imagen 1 de 3 Hover-1 H1 Shell Replacement, Shell: paso 15, imagen 2 de 3 Hover-1 H1 Shell Replacement, Shell: paso 15, imagen 3 de 3
    • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
    • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
  16. Hover-1 H1 Shell Replacement: paso 16, imagen 1 de 1
    • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
  17. Hover-1 H1 Shell Replacement: paso 17, imagen 1 de 1
    • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
    • Repeat for the left side of the shell.
  18. Hover-1 H1 Shell Replacement: paso 18, imagen 1 de 1
    • Lift the shell to remove it from the chassis.
Conclusión
Una persona más ha completado esta guía.
Sara Passantino
Miembro Desde 10/08/18
347 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
Miembros de 4
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,365
