Introducción
This guide explains how to remove the sensor assembly for your Hover-1 H1 hoverboard.
Partes
No se requieren partes.
  1. Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Puncture the two black stickers by using the tip of a screwdriver.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    • Unplug the battery by pulling gently on both sides of the orange connector.
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Conclusión
Aaron Teh
Miembro Desde 08/10/18
253 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 21
Todo El Tiempo: 58
