Introducción
This guide explains how to replace the lights on your Hover-1 H1 hoverboard.
  1. Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Puncture the two black stickers by using the tip of a screwdriver.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    • Unplug the battery by pulling gently on both sides of the orange connector.
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
Conclusión
Sara Passantino
Miembro Desde 08/10/18
305 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Miembros
7 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 45
Todo El Tiempo: 76
