Saltar al contenido principal
Hover-1 H1 LED Headlight Replacement
Qué necesitas
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: paso 1, imagen 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 LED Headlight Replacement: paso 2, imagen 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 LED Headlight Replacement: paso 3, imagen 1 de 2 Hover-1 H1 LED Headlight Replacement: paso 3, imagen 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 LED Headlight Replacement: paso 4, imagen 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: paso 5, imagen 1 de 1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 LED Headlight Replacement: paso 6, imagen 1 de 1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 LED Headlight Replacement: paso 7, imagen 1 de 1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
Conclusión
Una persona más ha completado esta guía.
Sara Passantino
Miembro Desde 10/08/18
347 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
Miembros de 4
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,418
