Saltar al contenido principal
Hover-1 H1 Charging Port Replacement
Qué necesitas
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: paso 1, imagen 1 de 1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: paso 2, imagen 1 de 1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: paso 3, imagen 1 de 2 Hover-1 H1 Charging Port Replacement: paso 3, imagen 2 de 2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: paso 4, imagen 1 de 1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: paso 5, imagen 1 de 2 Hover-1 H1 Charging Port Replacement, Charging Port: paso 5, imagen 2 de 2
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: paso 6, imagen 1 de 1
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: paso 7, imagen 1 de 2 Hover-1 H1 Charging Port Replacement: paso 7, imagen 2 de 2
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: paso 8, imagen 1 de 2 Hover-1 H1 Charging Port Replacement: paso 8, imagen 2 de 2
    • Pull the charging port to the left through the shell.
Conclusión
Madeline David
Miembro Desde 10/08/18
286 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G6, White Fall 2018 Miembro de Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
Miembros de 4
9 Guías creadas
2Guía Comentarios
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Contestar
Who can I contact to fix this charging port on this H one hover one hover board
Hover1 h1 hoverboard - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 32
Todo El Tiempo: 4,393
