Introducción
This guide explains how to remove the bottom shell of your hoverboard, which will allow you to gain access to most of the device's internals.
Qué necesitas
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Casi Terminas!
Conclusión
