Saltar al contenido principal
Hover-1 Folding E-Scooter Rear Wheel Replacement
Qué necesitas
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: paso 1, imagen 1 de 2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: paso 1, imagen 2 de 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 2, imagen 1 de 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 2, imagen 2 de 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 2, imagen 3 de 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 3, imagen 1 de 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 4, imagen 1 de 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 5, imagen 1 de 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 5, imagen 2 de 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 5, imagen 3 de 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: paso 6, imagen 1 de 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Conclusión
Luke Imai
Miembro Desde 10/08/18
133 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S15-G5, White Fall 2018 Miembro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
Miembros de 4
5 Guías creadas
2Guía Comentarios
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Contestar
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 29
Todo El Tiempo: 5,718
