Saltar al contenido principal
Hover-1 Folding E-Scooter LED Headlight Replacement
Qué necesitas
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: paso 1, imagen 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: paso 1, imagen 2 de 2
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: paso 2, imagen 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement: paso 2, imagen 2 de 2
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: paso 3, imagen 1 de 2 Hover-1 Folding E-Scooter LED Headlight Replacement: paso 3, imagen 2 de 2
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: paso 4, imagen 1 de 1
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
Conclusión
To reassemble your device, follow these instructions in reverse order with the new LED.
Nicolo DiFronzo
Miembro Desde 10/08/18
229 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S15-G5, White Fall 2018 Miembro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
Miembros de 4
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 3,392
