Saltar al contenido principal
Hover-1 Folding E-Scooter Brake Switch Replacement
Qué necesitas
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: paso 1, imagen 1 de 1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: paso 2, imagen 1 de 2 Hover-1 Folding E-Scooter Brake Switch Replacement: paso 2, imagen 2 de 2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: paso 3, imagen 1 de 3 Hover-1 Folding E-Scooter Brake Switch Replacement: paso 3, imagen 2 de 3 Hover-1 Folding E-Scooter Brake Switch Replacement: paso 3, imagen 3 de 3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
Conclusión
2 personas más completaron esta guía.
Brittani Kealoha
Miembro Desde 10/08/18
251 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S15-G5, White Fall 2018 Miembro de Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Miembros
5 Guías creadas
6 comentarios
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - Contestar
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - Contestar
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - Contestar
Looking new break switch.where we will get?. please reply.
Vitesh - Contestar
Looking for a throttle switch. Know where I can find one?
Mara - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 44
Todo El Tiempo: 4,920
