Saltar al contenido principal
Hover-1 Coast Wheel Replacement
Qué necesitas
  1. Hover-1 Coast Wheel Replacement, Wheel: paso 1, imagen 1 de 1
    • Identify the wheel you are wanting to replace.
  2. Hover-1 Coast Wheel Replacement: paso 2, imagen 1 de 2 Hover-1 Coast Wheel Replacement: paso 2, imagen 2 de 2
    • Find the Socket wrench located in the Hover-1 Coast packaging.
    • Use the 9/16 inch side to loosen the skateboard nut by turning counterclockwise.
  3. Hover-1 Coast Wheel Replacement: paso 3, imagen 1 de 3 Hover-1 Coast Wheel Replacement: paso 3, imagen 2 de 3 Hover-1 Coast Wheel Replacement: paso 3, imagen 3 de 3
    • Remove the nut off the axle.
    • Remove the washer off the axle.
  4. Hover-1 Coast Wheel Replacement: paso 4, imagen 1 de 3 Hover-1 Coast Wheel Replacement: paso 4, imagen 2 de 3 Hover-1 Coast Wheel Replacement: paso 4, imagen 3 de 3
    • To avoid losing any parts, place them on a flat surface.
    • Slide the unwanted wheel off the axle.
    • Slide the new wheel on the axle.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 430
