Saltar al contenido principal
Hover-1 Coast Trucks Replacement
Qué necesitas
  1. Hover-1 Coast Trucks Replacement, Trucks: paso 1, imagen 1 de 3 Hover-1 Coast Trucks Replacement, Trucks: paso 1, imagen 2 de 3 Hover-1 Coast Trucks Replacement, Trucks: paso 1, imagen 3 de 3
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: paso 2, imagen 1 de 3 Hover-1 Coast Trucks Replacement: paso 2, imagen 2 de 3 Hover-1 Coast Trucks Replacement: paso 2, imagen 3 de 3
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: paso 3, imagen 1 de 3 Hover-1 Coast Trucks Replacement: paso 3, imagen 2 de 3 Hover-1 Coast Trucks Replacement: paso 3, imagen 3 de 3
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
Conclusión
Alaina Limon
Miembro Desde 10/04/18
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 265
