Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
  1. To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board. Using a pick tool, puncture the grip tape and expose the screws. Loosen all four 1" screws using a Phillips #1 screwdriver.
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Now pull the black protective cover off the board. Locate the battery. Locate the battery.
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. The battery is connected by these two sets of wires. Remove the yellow wire first by pulling the two wires gently in opposite directions. Now pull apart the black wire by gently pulling the two wires in opposite directions.
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Once the battery has been disconnected, gently pry the battery upward. It is important to use a plastic opening tool to avoid puncturing the battery. Once the battery is freed, remove it with your hands.
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
  5. Using the Phillips #1 screwdriver, loosen the two screws and  place the power button somewhere safe. Using the Phillips #1 screwdriver, loosen the two screws and  place the power button somewhere safe. Using the Phillips #1 screwdriver, loosen the two screws and  place the power button somewhere safe.
    • Using the Phillips #1 screwdriver, loosen the two screws and place the power button somewhere safe.
  6. Remove the unwanted spring and place your new spring back into the hole. Remove the unwanted spring and place your new spring back into the hole.
    • Remove the unwanted spring and place your new spring back into the hole.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 121
