Saltar al contenido principal
Hover-1 Coast Controller Battery Replacement
Qué necesitas
  1. Hover-1 Coast Controller Battery Replacement, Controller Battery: paso 1, imagen 1 de 3 Hover-1 Coast Controller Battery Replacement, Controller Battery: paso 1, imagen 2 de 3 Hover-1 Coast Controller Battery Replacement, Controller Battery: paso 1, imagen 3 de 3
    • Identify the three screws and using a Phillips #1 screwdriver loosen the the screws.
    • Remove the three screws.
  2. Hover-1 Coast Controller Battery Replacement: paso 2, imagen 1 de 3 Hover-1 Coast Controller Battery Replacement: paso 2, imagen 2 de 3 Hover-1 Coast Controller Battery Replacement: paso 2, imagen 3 de 3
    • Pull the backside of the controller off.
    • The inside of the controller should look like this.
    • The marked area is the battery.
  3. Hover-1 Coast Controller Battery Replacement: paso 3, imagen 1 de 1
    • Remove the black foam piece covering the battery.
  4. Hover-1 Coast Controller Battery Replacement: paso 4, imagen 1 de 2 Hover-1 Coast Controller Battery Replacement: paso 4, imagen 2 de 2
    • Desolder the battery connections from the motherboard.
  5. Hover-1 Coast Controller Battery Replacement: paso 5, imagen 1 de 2 Hover-1 Coast Controller Battery Replacement: paso 5, imagen 2 de 2
    • Using a plastic opening tool, pry the battery off the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 417
