Saltar al contenido principal
Introducción
To fully access all parts of the Hover-1 Chrome, the entirety of the outer shell must be removed. This guide will go over how to completely remove the outer shell.
Partes
No se especificaron partes.
  1. Flip the Hover-1 Chrome upside down.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell without the speaker grille and unplug the battery.
  3. Lift the shell with the speaker grille. Unplug the speaker.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  6. Free the cables held atop the bracket holding the battery in place. Remove the four 14 mm Phillips #2 screws  holding the battery bracket in place. Pull the battery bracket free.
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  7. Unplug the cords for the top LEDs.
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  8. Turn the board over and pull the top panel off.
    • Turn the board over and pull the top panel off.
Linea de Meta
Dylan Prins
Miembro Desde 08/10/18
209 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S4-G1, White Fall 2018 Miembro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 53
