Introducción
The motherboard stores and communicates software necessary to ride the Hover-1. Replacing the motherboard acts like a reset button. You will need a Phillips #2 screwdriver and a soldering iron.
Partes
No se requieren partes.
  1. Flip the Hover-1 Chrome upside down.
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell without the speaker grille and unplug the battery.
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
    • Disconnect the speaker cable.
    • Disconnect the cable that travels to the other motherboard.
    • Disconnect the smaller connector midway on the cable.
    • Disconnect the larger connector midway on the cable.
    • Remove the four 12mm Phillips #2 screws securing the motherboard.
    • Locate the five solder locations on the underside of the motherboard.
    • Plug in soldering iron and wait for the tip tip to reach its target temperature.
    • Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the motherboard.
    • Be aware of where the tip of the soldering iron is at ALL times. Put on safety glasses before picking up the soldering iron. Turn on a fan and face it towards the device to vent harmful fumes away from the solderers face.
Conclusión
Nick McGuire
Miembro Desde 08/10/18
539 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G1, White Fall 2018 Miembro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 14
Todo El Tiempo: 45
