Saltar al contenido principal
Hover-1 Chrome LED Headlights Replacement
Qué necesitas
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: paso 1, imagen 1 de 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: paso 2, imagen 1 de 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: paso 3, imagen 1 de 2 Hover-1 Chrome LED Headlights Replacement: paso 3, imagen 2 de 2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: paso 4, imagen 1 de 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: paso 4, imagen 2 de 3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: paso 4, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: paso 5, imagen 1 de 2 Hover-1 Chrome LED Headlights Replacement: paso 5, imagen 2 de 2
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: paso 6, imagen 1 de 3 Hover-1 Chrome LED Headlights Replacement: paso 6, imagen 2 de 3 Hover-1 Chrome LED Headlights Replacement: paso 6, imagen 3 de 3
Conclusión
Nick McGuire
Miembro Desde 10/08/18
551 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G1, White Fall 2018 Miembro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 166
