Saltar al contenido principal
Hover-1 Chrome Bluetooth Speaker Replacement
Qué necesitas
  1. Hover-1 Chrome Bluetooth Speaker Replacement, Bluetooth Speaker: paso 1, imagen 1 de 1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Bluetooth Speaker Replacement: paso 2, imagen 1 de 1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Bluetooth Speaker Replacement: paso 3, imagen 1 de 1
    • Lift the shell with the speaker grille so the speaker can be accessed.
    • Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
  4. Hover-1 Chrome Bluetooth Speaker Replacement: paso 4, imagen 1 de 3 Hover-1 Chrome Bluetooth Speaker Replacement: paso 4, imagen 2 de 3 Hover-1 Chrome Bluetooth Speaker Replacement: paso 4, imagen 3 de 3
    • Pull off the bracket holding the speaker in place.
    • Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
  5. Hover-1 Chrome Bluetooth Speaker Replacement: paso 5, imagen 1 de 2 Hover-1 Chrome Bluetooth Speaker Replacement: paso 5, imagen 2 de 2
    • Disconnect the cable attaching the speaker to the sound card.
Conclusión
2 personas más completaron esta guía.
Nick McGuire
Miembro Desde 10/08/18
551 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G1, White Fall 2018 Miembro de Cal Poly, Team S4-G1, White Fall 2018
CPSU-WHITE-F18S4G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 629
