Saltar al contenido principal
Hover 1 Eclipse Motherboard Replacement
Qué necesitas
  1. Hover 1 Eclipse Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
    • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Motherboard Replacement: paso 2, imagen 1 de 3 Hover 1 Eclipse Motherboard Replacement: paso 2, imagen 2 de 3 Hover 1 Eclipse Motherboard Replacement: paso 2, imagen 3 de 3
    • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the bottom left shell piece.
  3. Hover 1 Eclipse Motherboard Replacement: paso 3, imagen 1 de 1
    • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
  4. Hover 1 Eclipse Motherboard Replacement: paso 4, imagen 1 de 3 Hover 1 Eclipse Motherboard Replacement: paso 4, imagen 2 de 3 Hover 1 Eclipse Motherboard Replacement: paso 4, imagen 3 de 3
    • Unplug the yellow tipped plug attached to the red and black cords.
    • Unplug the black headers attached to the white, skinny cord.
    • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
  5. Hover 1 Eclipse Motherboard Replacement: paso 5, imagen 1 de 2 Hover 1 Eclipse Motherboard Replacement: paso 5, imagen 2 de 2
    • Unplug the white header attached to the pink and white cord.
    • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
    • Repeat steps 3 and 4 on the other side.
  6. Hover 1 Eclipse Motherboard Replacement: paso 6, imagen 1 de 1
    • You have now removed the motherboards from both sides.
Conclusión
Mina Dedijer
Miembro Desde 10/10/19
545 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S12-G4, Regan Fall 2019 Miembro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Miembros
5 Guías creadas
7 comentarios
Can you please drop links to purchase the 2 motherboards?
Frank - Contestar
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - Contestar
We’re do you get the boards at I really need them
Ashton Mcalvain - Contestar
We’re do get the boards?
Hector Ortiz - Contestar
Any idea where to buy parts and the price?
william bowen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 2,127
