Saltar al contenido principal
Hover 1 Eclipse Charging Port Replacement
Qué necesitas
  1. Hover 1 Eclipse Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 Hover 1 Eclipse Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
    • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
    • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
  2. Hover 1 Eclipse Charging Port Replacement: paso 2, imagen 1 de 1
    • Unscrew the ring around the inside section of the charging port.
  3. Hover 1 Eclipse Charging Port Replacement: paso 3, imagen 1 de 1
    • Follow the wire back from the charging port to where it plugs into the board.
    • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
  4. Hover 1 Eclipse Charging Port Replacement: paso 4, imagen 1 de 2 Hover 1 Eclipse Charging Port Replacement: paso 4, imagen 2 de 2
    • Pull the charging port and wire attached to it out through the front side of the port.
    • Take the plastic protector off of the charging port.
Conclusión
Mina Dedijer
Miembro Desde 10/10/19
545 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S12-G4, Regan Fall 2019 Miembro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 782
