Saltar al contenido principal
Hover 1 Eclipse Bluetooth Speaker Replacement
Qué necesitas
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: paso 1, imagen 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: paso 1, imagen 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: paso 1, imagen 3 de 3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: paso 2, imagen 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: paso 2, imagen 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: paso 2, imagen 3 de 3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: paso 3, imagen 1 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: paso 3, imagen 2 de 3 Hover 1 Eclipse Bluetooth Speaker Replacement: paso 3, imagen 3 de 3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
Conclusión
Mina Dedijer
Miembro Desde 10/10/19
545 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S12-G4, Regan Fall 2019 Miembro de Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 325
