Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Household Item AcuRite 02081M Observer Repair Replacement
  1. Household Item AcuRite 02081M Observer Repair Replacement, AcuRite 02081M Observer Repair: paso 1, imagen 1 de 1
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Household Item AcuRite 02081M Observer Repair Replacement: paso 2, imagen 1 de 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Household Item AcuRite 02081M Observer Repair Replacement: paso 3, imagen 1 de 1
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Household Item AcuRite 02081M Observer Repair Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Conclusión
anhut51190
Miembro Desde 07/04/19
281 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 255
