Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The Hot Wheels AI Intelligent Race System may experience jammed or broken buttons on the controller. Be careful when disassembling the controller as wires can break or circuits can be damaged.
Partes
No se especificaron partes.
  1. Remove the six screws located on the back of the controller using a #J1 JIS head screwdriver.
    • Remove the six screws located on the back of the controller using a #J1 JIS head screwdriver.
  2. Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
    • Pop the front of the controller casing from the back and carefully lay the controller out with circuits exposed.
  3. Locate controller buttons at the top of the controller. They are blue and red. Check for debris that may be jamming buttons or broken buttons. Locate controller buttons at the top of the controller. They are blue and red. Check for debris that may be jamming buttons or broken buttons.
    • Locate controller buttons at the top of the controller. They are blue and red. Check for debris that may be jamming buttons or broken buttons.
  4. If buttons are jammed or broken easily remove them by snapping them up and out of place. Replace buttons with new ones or clear debris and clean buttons. If buttons are jammed or broken easily remove them by snapping them up and out of place. Replace buttons with new ones or clear debris and clean buttons.
    • If buttons are jammed or broken easily remove them by snapping them up and out of place. Replace buttons with new ones or clear debris and clean buttons.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 170
