Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your Hot Wheels AI controller does not turn, try replacing the battery. This guide will assist you if you have any trouble. Before you begin, you will need three brand new AAA batteries and a J0 screwdriver. The steps should be straightforward and fast! Once you replace your battery, you will be racing in no time!
Partes
No se especificaron partes.
  1. Use a JIS #0 screwdriver to unscrew the single battery cover screw.
    • Use a JIS #0 screwdriver to unscrew the single battery cover screw.
  2. Remove the old AAA battery from the slot by pressing down on the positive end. Do the same for the other two. Make sure none of the battery slots are damaged.
    • Remove the old AAA battery from the slot by pressing down on the positive end.
    • Do the same for the other two. Make sure none of the battery slots are damaged.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 124
