Introducción
In this replacement guide, we will walk you through the first steps to take to replace most things on your Hot Tools HPK12 flat iron. Be sure to have the device powered off, unplugged, and completely cooled down before beginning.
Qué necesitas
Remove round plastic cover near cord base by prying under the side with the metal spudger.
Flip the device and remove the other round plastic cover near the base of the cord.
Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
Lift the backing plate upwards to remove it from the flat iron.
Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
