Introducción
Hornady lock n load auto charge
Having issues with Motor not running
Inconsistent speeds/ jerking around.
install new IC to fix the issue
Clean Brushes on Motor
  1. Horandy Auto Charge
    • Horandy Auto Charge
  2. Empty Powder out Remove anything that will fall out when you turn it over to get to the 6 phillips screws in the botton
    • Empty Powder out
    • Remove anything that will fall out when you turn it over to get to the 6 phillips screws in the botton
    • remove the 4 round foam feet to exposed the screws. unscrew the 6 screws
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. slowly separate the black bottom from the red top. there is a motor connecter, screen connector, and 2 connector for the keypad.
    • slowly separate the black bottom from the red top. there is a motor connecter, screen connector, and 2 connector for the keypad.
  5. There is 1 circuit board and you can see the l298n on the right side. take circiut board out and unsoder the l298n.  install New L298n with Heat sink . and reassemble.
    • There is 1 circuit board and you can see the l298n on the right side. take circiut board out and unsoder the l298n. install New L298n with Heat sink . and reassemble.
  6. You can see the damage to the L298N
    • You can see the damage to the L298N
    • required a new Motor Controller IC. This happened loading 300 Cartridges back to back. Duty Cycle was to much. ADDED heat sink is a must if loading may Cartridges!!!
    • when testing after new IC was installed
    • Motor would Jerk and was not smooth. disassemble motor and clean brushes.
Conclusión
Una persona más ha completado esta guía.
Brent Felzien
Miembro Desde 16/10/18
133 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 18
Todo El Tiempo: 93
