Saltar al contenido principal
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
Qué necesitas
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: paso 1, imagen 1 de 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: paso 1, imagen 2 de 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 2, imagen 1 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 2, imagen 2 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 2, imagen 3 de 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 3, imagen 1 de 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 3, imagen 2 de 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: paso 4, imagen 1 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: paso 4, imagen 2 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: paso 4, imagen 3 de 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 5, imagen 1 de 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 6, imagen 1 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 6, imagen 2 de 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: paso 6, imagen 3 de 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Conclusión
2 personas más completaron esta guía.
steven hoover
Miembro Desde 09/26/17
257 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 53
Todo El Tiempo: 3,822
