Saltar al contenido principal
Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement
Qué necesitas
  1. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: paso 1, imagen 1 de 2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: paso 1, imagen 2 de 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: paso 2, imagen 1 de 3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: paso 2, imagen 2 de 3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: paso 2, imagen 3 de 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: paso 3, imagen 1 de 2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: paso 3, imagen 2 de 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
Linea de Meta
Spencer Nefores
Miembro Desde 09/26/17
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G2, Banghart Fall 2017 Miembro de Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 40
Todo El Tiempo: 3,043
