Introducción
The primary air filter is in the vacuum's dust cap and prevents dust from being sucked out of the dust cup.
It's designed to be easily cleaned or replaced, so it's a quick process.
If your filter merely needs to be cleaned, you can follow this guide, but instead of replacing the filter you can rinse it under a faucet and reinstall it.
Qué necesitas
Press button on the top of the dust cup and pull back.
Remove dust cup from vacuum
Una persona más ha completado esta guía.
Un comentario
Can I rinse it with warm water and soap? Or just warm water?
