Saltar al contenido principal
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
Qué necesitas
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: paso 1, imagen 1 de 1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: paso 2, imagen 1 de 1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: paso 3, imagen 1 de 1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: paso 4, imagen 1 de 1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
Conclusión
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
6 personas más completaron esta guía.
Mickey McGuire
Miembro Desde 01/22/18
253 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G4, Banghart Winter 2018 Miembro de Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Miembros
10 Guías creadas
6 comentarios
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - Contestar
Same issue. Easy fix thanks!
mark camirand - Contestar
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - Contestar
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 140
Todo El Tiempo: 27,876
